I'm really sorry if this is the wrong forum, but I purchased my PC online and on the front of the case there is a electronic temperature meter (small circle screen with temperature and time on it). I seriously do not know what temperature this is measuring, whether it be the CPU temperature, the Case Temperature, it's definitely not the GPU temperature because I have Thunder Master (a program for monitoring GPU temps) and the temps are different. The temperature on the front can range from 27 degrees up to 41 degrees (the highest I've ever seen it), what could this be and currently it's quite hot where I am and the temperature is 37 degrees on the case, is this worrying? I'm just curious of what it's temp it's measuring, I suspect it's the CPU temp.
