DanteChiesa,
Welcome to Tom's!
At the top of each Forum you will see "Stickies", which are permanent special information threads. In the "CPU's" Forum and "Overclocking" Forum you will see this one:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
There is a proper way to test your Core temperatures at
steady-state 100% workload and at
dead idle. Please give it a read to get yourself up to speed on this topic.
Idle temperatures are of minor importance. Load temperatures are critical.
What is your ambient temperature?
Are you using Intel's stock cooler?
Guys,
"TjMax" is the "Core" temperature at which the processor will "Throttle" for thermal protection. The spec for the i5 3570K is 105C.
Although "Tcase" for the i5 3570K is 67C, this is "CPU" temperature, NOT "Core" temperature.
Core temperature is 5C higher than CPU temperature due to the differences in sensor type, location and calibration. Tcase + 5 makes the corresponding Core temperature 72C.
<-- This is the spec, but we know that mid 70's are safe.
Intel desktop processors have thermal sensors for each Core, plus a sensor for the entire processor, so a Quad Core has five sensors. Heat originates within the Cores where Digital sensors measure Core temperatures. A single Analog sensor under the Cores measures overall CPU temperature.
The relationship between Core temperature and CPU temperature is not in the Thermal Specifications; it's only found in a few engineering documents. In order to get a clear perspective of processor temperatures, it's important to understand the terminology and specifications, so please read the
Thanks,
CT
