[SOLVED] temps and voltages i7 8700
Apr 24, 2019
34
j3ster
374
32
4,990
56
use HWinfo64 and post pics from there its more accurate, but with a cpu at 70c-75c on load is not that bad anything above 80 tho is a worry but could be better heat is one main factor for component degradation personally id want around 65c at full load, but dont worry too much about it you are still well within spec ^_^ , for voltages anything below 1.4 for a daily use pc is fine and safe so no worries there.
Reactions: gikal
Apr 24, 2019
34
thank you for the answer sir :D i found the problem it was my case, the dust filters obstructed the air flow, now i got like 8-11 c less on the system.
View: https://www.youtube.com/watch?v=dNnMC0jtfos&t=880s
j3ster
374
32
4,990
56
thats good to know that it improved with a little cleanup. just do it regularly also make sure you have a positive airflow setup to minimize dust collection within your pc. i tend to blower my pc atleast twice a month esp the radiators.
Reactions: gikal
