Hello,
I recently got a new motherboard (Tyan Tomcat K8E s2865) and due to size constraints around the socket, the biggest heatsink I could go with is the XP-90 with Thermalright's recommended Panaflo 92mm fan (medium speed 48 CFM@ 2450RPM). With casual usage I get temps between 40C-42C with the case closed (Antec Sonata II). With Cool&Quiet enabled I can get those temps down to around 37C-38C. But under load (2x instances of F@H or 1x F@H and 1x prime95) the cpu will rise up to 59C with the case closed and 57C with an open case.
Temps don't seem to vary greatly between the case being open or closed. I haven't experienced any issues concerning system stability either. Would just like to know if these temps are common or what fan are people using on an XP-90? Maybe I was just babied with the Zalman 77000cu I had, couldn't get the cpu higher than 47C no matter what. Thanks.
