Temps on a i7-2600k @ 4.6 GHz with Cooler Master Evo 212
charlie460
4
I have a Intel Core i7-2600k OC'd to 4.6 GHz (HT on) running at 1.328 Vcore at full load with IntelBurnTest.
When running IntelBurnTest, temps reach up to 85 C. Is this normal for a 4.6 GHz OC with that voltage on the CM 212 Evo? Seems a bit high to me, but obviously my temps are not typically going to be that high, this is in IntelBurnTest only.
Thoughts?
Thanks!
nukemaster
I have seen stock(stock cooler and speed) get into the 80s without overclocking so you are good at 75.
Little if any real world use(Shy of folding @ home or video compression both things that are done with video cards more and more) will get your cpu that hot.
Enjoy the system.
Similar threads
