Ok. My two cents for the people who use this rig (very common among pc gamers as you can see in the forum)
My box:
MB Bios 602
Mem settings: 2 GB at 4-4-4-12 Trc 22 and Cmd Rate 2 w/ voltage 2.084
CPU in manual OC: Rated FSB at 1250 (gives 2.8ghz) linked in a 2:3 mem ratio (resulting 833,3 mhz) with a Cpu voltaje: 3.875 v
Disable all spectrums and extra CPU options, also disable all not needed in bios (sound, raid, qfan, etc)
Video is Evga 8800 gts 640mb superclocked, OC to 625/950, stock cooling, NGO optimized drivers, ver. 1.15822 (idle 67, load 81 C°) and Riva Tuner loaded
3 Hard Drives (two maxtor 160GB in raid 0 and a 300GB maxtor as backup)
Agiler 1000w PS
SB X-fi sound platinum
In the background runs AVG Antivirus, Rocketdock and Creative Software
Cooling is made by Thermaltake Big Water SE liquid sistem (not terrible efficient but decent temps on a Viking case) with one 12" fan intake and one 12" fan outake (thermaltake, so their speed can be regulated)
The room temp is in the 25 - 26 C° (a little high, I know) and the inside case ambient temp, as the case probe tells, is 33.8 C°
In order to achieve the "Computronix Law's" for the 6600 C2D, temperatures (juntion is always 15° higher than cores), using Orthos Beta, I did as follow:
With the fans at normal speed I recalibrated the cpu temp (using speedfan here) by -5 C° so the reading, at 2 hours using orthos, is as follow:
CPU 44°
Core 0 58°
Core 1 57°
If the fans are turned on high speed, all temps drop by 2 °C
The system is rock solid and gives a +10500 points at 3Dmark06
My box:
MB Bios 602
Agiler 1000w PS
CPU 44°
Core 0 58°
Core 1 57°
