I built a uATX system in a Silverstone SG-01 case. This is a tight unit and I'm wondering about temperatures. I have a Silverstone Stryder ST75F-P power supply. The CPU sits right below it and I swapped out the standard Intel cooler for a Shuriken Low profile. The thing is the PS's fan is on the bottom and I think it sucks air out. That would mean that it is venting hot air toward the CPU cooler and therefore is blowing hot air into the Shuriken. My temps at idle are 55-57c (real Temp) and when I fireup AutoCad, Photoshop, Sketchup They go into 60's and I've seen 72. (I am in a hot room and my monitors are putting out a lot of heat)
I've set the CPU fan speed to Turbo in AI suite's FanXpert. There is not that much noise difference between modes so I can live with it, but I'm concerned that the temps are still too high. Answers, suggestions?
There are 6 fans running in this tight case.
GPU fan
2 case fans sucking air out.
1 sucking air over the HDs
PS fan
CPU fan.
System:
Windows 7 Pro 64
ASUS Rampage Gene III
Intel i7 930
ATI FirePro V4800
6gb Corsair Dominator 1600
Crucial SSD 128gb Drive
WD 1T drive
Silverstone ST75F-P PS
GPU fan
PS fan
CPU fan.
System:
Windows 7 Pro 64
Intel i7 930
ATI FirePro V4800
WD 1T drive
