Temps / Pressure / Airflow
kenchu
73
Hey guys, I am planning to build a non-gaming pc inside the cooler master elite 343 micro atx case. I will use an Amd Apu A8 7600 with stock cooler.
The case comes with one 120mm fan that spins at 1200rpm with 0.86 mmH2O air pressure (CFM???).
I am planning to install a dust filter for that intake. I am not planning to install exhaust fans.
> Will this make my temps go a lot (dangerously) higher than normal?
(A lot higher than if I have an exhaust fan too)
[I don't mean just thermal throttle, I mean also shorting cpu's life due to usage at high temps, sorry if I'm ignorant]
>Will this generate a possitive air pressure so it will keep dust away?
>Replacing the fan with a higher rpm, higher cfm , will make my temps go a lot lower?
Thank you!
It will run just fine ,Luke from NCIX computer review studio, did a video ......Where they basically filled the case which stuff to stop air flow on a low end non overclocked system and I think the CPU went up only 17 degrees with everything covered Having said that I wouldn't do that with an overclocked 7700k or a 9590 Link ttps://www.youtube.com/watch?v=YDCMMf-_ASE
FullmetalJacket
Commendable
Feb 13, 2017
169
