I read the instructions they are not super good since your home router IP range may not be 192.168.0.xxx but .1.xxx which means your computer won't connect to the device by default which should be explained better. Did you change the IP settings in the computer you are trying to connect to? Make sure the settings in the setup guide are in the computer.
Also check the setup guide for the status lights and make sure they are all showing good connection to the network.
