K keng2491 Jun 14, 2018 34 0 30 Jun 15, 2018 #1 Hi, I just finished building my PC thanks to you guys for answering my question. Now I have more... Can anyone one tell me how I can check if all of my parts in the PC is working?
Solution Roland Of Gilead Jun 15, 2018 Something like this is what you need : https://www.passmark.com/products/bit.htm It's burn in test to load your components to make sure they run as they should. You can also compliment it with something like HWMon to watch your hardware usage/temps whilst doing the test.
Roland Of Gilead Titan Aug 8, 2008 12,041 3,042 83,240 Jun 15, 2018 Solution #2 Something like this is what you need : https://www.passmark.com/products/bit.htm It's burn in test to load your components to make sure they run as they should. You can also compliment it with something like HWMon to watch your hardware usage/temps whilst doing the test. Upvote 0 Downvote Solution
Roland Of Gilead Titan Aug 8, 2008 12,041 3,042 83,240 Jun 15, 2018 #4 keng2491 : Thank you! You're most welcome Good luck with the new build! Upvote 0 Downvote
