Testing PSU with "Power Supply Tester"
zakariel76
6
I would like to test the power output of my PSU (EVGA G2-850W) as my PC has stability issues when running BF1 (the PC totally freezes and even the sound gets locked; the only way is to hard reset).
I have been looking around for multimeters however the one used in this tutorial costs north of 200 Euros. Then I happened across a tester called "Power Supply Tester", though i'm a bit suspicious as to whether it works or not (it only costs like 6 USD on ebay).
Any thoughts on if "Power Supply Tester" works or if there is a cheaper multimeter alternative than the one used in lifewire that I should be using instead?
A power tester will only tell you if the PSU works on the most basic level. It's not a multimeter or a load tester.
What are the complete specs? There are a number of causes for freezing.
Here are my complete specs.
  • GPU: ASUS Radeon R9 290 4GB DirectCU II OC (R9290-DC2OC-4GD5)
    MOBO: ASUS X99-DELUXE
    CPU: Intel Core i7-5820K, Socket-LGA2011-3
    PSU: EVGA Supernova G2 850W
    RAM : 4x Crucial Ballistix DDR4-2400 SP QC - 16GB
    SSD: Samsung 850 Pro 512
    HD: Seagate Barracuda 2TB
    CASE: NZXT Phantom 410
    HSF: Noctua NH-U12S
Even though I should be way below my max PSU capacity with my single AMD R9 290 I thought it might be worth looking into. I used to have total lockups on a previous PC, and found out that my PSU (which was top rated) was part of a bad batch so i'm a bit paranoid.
A simple psu tester in the $15 range is good for only one thing.
If your psu fails the test, you can be certain it is bad.
Otherwise, a simple tester has no value in determining the proper operation of a psu, even if all the "tests" are good.
For the ordinary user, the only way to confirm a bad psu is to test with a known good unit.
