TF2 help (dont just read!)
Dusanking123
63
I got filesystem_stdio.dll unable to load error,i fixed it by copying bin files from source sdk 2007 to tf's bin.But i get unable to load materials/console/background01.vtf,then i make materials/console in hl2 folder and copy that .vtf file from sdk 2007 there,then i get startup_loading.vtf unable to load and do same,just from another game location.Then i get unable to load lib client,then(again) i copy client.dll and server.dll from source sdk 2007/sourcetest/bin to tf/bin and i get some manifest error that ends with .txt,help? tried veryfing cache dont just read again '_'
Explain your problem better, or in another way.
The way you wrote is confusing and hard to read.
Use some new lines, paragraph, more comas and spaces. please.
Yeah,right...
First,when i got tf2 and try to launch it i get unable to load D:/Steam/steamapps/common/Team Fortress 2/bin filesystem_stdio.dll
After copying all files from source sdk 2007 bin,i get unable to load materials/console/background01.vtf
By the way,i get valve logo...
After i copy that vtf file,i get startup_loading.vtf is missing,i copy it then and get to that loading,white screen...
Then it crashes with some manifest .txt error that's unable to load in scripts/
I try to copy it from somwhere,but it get some error its not right file,or something...
I tried verifying game cache,but nothing...even deleting scripts folder,bin,materials and then redownload em...
I hope you can help... Ty in advance :)
Yes,i reinstalled it 100 times...I heard they removed sse2 support...
When i installed it first time,i started immediatelly and that happened :/
Maybe you guys can upload materials and scripts files if you have ??
I dunno im not expert :/
I play TF2 every day. I've never had a problem with it. An updated version of TF2 should have no problem running on a machine. I'd work on getting it running before you start worrying about modding/adding scripts. I'd delete it from your library then have Steam reinstall it. Try running it. Fixed?
I did all to fix it,so i came here... Before i had a serious error,and had to reinstall whole steam + lose 40gb of games for these errors... As i said i reinstalled 100 times,it will just come again to unable to load filesystem_stdio.dll...and i will again fix it to this manifest,its steam version ofc
