TG784 Timing connections
svirve
5
I know some routers have the possibility to put a timer when connections are able to be made through the router.
Say between 06:00 and 22:00 computer A is able to connect to the internet through the router.
Computer B can connect to the internet between 06:00 and 20:00.
Computer C can connect to the internet all the time.
I've been looking for this function in my Thompson TG784 but I'm not able to find it.
I''ve searched through the manual and came up with nothing.
Anyone have any experience with a TG784 that knows how to setup such a timer?
Closing down the entire network is not interesting.
Thanks beforehand // Svirve
wacabletech
219
Would that be a comcast product from arris? If so 10.0.0.1 is the config IP, admin/password should be the login. Unless, of course, you changed it.
After that parental controls is probably what you are looking for, on the left hand column. Probably managed devices or services depending on what you are trying to do.
