The best 120mm Case fan
altairscreed
15
Hey guys Im planning on buying the Cooler Master Silencio 550 case but I need to buy an extra 120mm intake fan, does anyone have any suggestions on the best one to get?
Thanks for reply's guys but I probably should have mentioned that noise and cost dont really bother me as this case only supports 2xin-take fans and 1 exhaust fan so I want an inlet fan that basically provides the best air intake to my cpu. thanks again :) also if anyone has or previously had the case I mentioned what are your opinions on it if running a high end oc'd card (cooling wise).
I'll check these now man, much appreciated.
Are the Deepcools as quiet as the Noctuas? I'm also about to order a few new fans for my system and have owned Noctua fans that have been just amazing.
Check out this review. Convinced me to get the Gentle Typhoons and I'm very happy with them.
http://martinsliquidlab.org/2013/05/07/fan-testing-round-12/
Note they are tested as rad mounted.
yes , just as quiet , great fan if you can find at a good price , talking the SF line not the cheap line of deepcool fans , realy great quality fans , sleeved cables , adapters ans a rubberized fan surround . Plus been running them for 1 1/2 years and no dust on them ?? Can't figure that out , all the other fans are loaded with dust .
