The best graphic card I can upgrade to for my system.. HELP!
lkyyun
Hi experts,
So my system is now three years old and I do not realize the urge to upgrade anything until I get in touch with the Total War series...
Here is my specs:
Motherboard: Asus M2N-E SLi
CPU: AMD Athlon X2 Dual Core 6000+ (3.02Ghz)
Memory: Kingston DDR2 4GB RAM
Hard Drive: WD 500GB
PSU: Corsair VX 450W
OS: Windows 7 Ultimate 32bit
Graphic Card: Asus GeForce 8600GTS
Without upgrading any other parts, what is the best graphic card now that I can purchase that will work properly and without bottlenecking the card?
I also have a friend wanting to sell me his MSI GTX465 Twin Frozr II card. What minimum upgrade do I need to get the card running? I understand the card is power hungry, so my next card in line is GTS 450. If this card fits better, I will buy this instead.
Here are more details on the PSU
Picture of the amperes:
Cables:
20+4 Pin Main x 1
8 Pin CPU x 1
4 Pin CPU x 1
4 Pin Molex x 6
4 Pin Floppy x 2
SATA x 6
6 Pin PEG (PCI Express Graphics) x 1
THANK YOU SOOOOOOO MUCH FOR THE HELP!
I checked the power consumption, the GTS450 doesn't use that much more than 8600GTS. maybe 10~20W in full. Since the minimum requirement for GTS450 is 400W, while my psu got good amp at 12V and actually rated as 500W so I thought it should work.
Just wondering if my system will bottleneck the card. Thx.
