from what i've been reading it seems that everyone *hates* HDD water blocks. it seems like whenever someone brings one up, the standard reply is "they're useless unless you want a brick wall in your flow" which is then normally followed up by a "you'd do better putting some 120mm fans on them"
i'm in the middle of trying to design my cooling system and have been trying to research water cooling b/c it seems like it would would best implement the philosophy behind my new computer. one, I want a compact system. in this area i can see room for debate. water lines may have a tough time winding through a small system, but on the other hand, airflow is going to be a nightmare too. two, i want good performance. even though i'm not really planning on OCing, i still want to maintain a cool working envirnment for my components as well as a low ambient case tempurature. finally, and i think this is where water is going to be right for me, i want a very quiet system. i've been hearing a lot of people saying that you can't beat water for perforamce/noise ratio, which is exactly what i'm looking for.
now that i've gone completely off topic, i'll bring it back. i'm planning on putting 2x 36gig raptors in raid 0. i've heard these things run really hot, so immediately my first response is "can i put water blocks on them?" but everyone seems so dead set against that. i heard it might restrict flow, which prompts me to ask, what about running "low flow" lines for the HDD (and possibly chipset as well, since i've heard they really don't need high performance water) parallel to the main lines. it seems like that would solve both problems by not restricting flow to the cpu and gpu while still providing a quieter more effective cooling solution for the HDDs.
any thoughts?
any thoughts?
