Question The leds of my ARGB fans don't work or get stuck in the same color
Dec 25, 2024
5
I've been using my computer for 1.5 years, and until a month ago, the fan LEDs were working without any issues. However, recently, the ARGB lights have either stopped lighting up or gotten stuck on the same color.
At first, I thought the fan LEDs were faulty because the RGB lights on my liquid cooling system were working flawlessly in the selected mode and color in the software. However, strangely, I noticed that about 35-40 minutes after starting a game, the ARGB fans would return to the colors and mode set in the software. Because of this, I checked the software but couldn't find a solution.
I don't think there's an issue with the wiring since I haven't made any changes to it, and as I mentioned, after 35-40 minutes of gaming, everything starts working normally again. Does anyone know how to fix this issue?
OS:Windows 11 Pro
Psu:High Power Element-DD GD 750W 80+ Bronze (1 Year old it came with my case.)
Disk Drive: Kingston NV2 SNV2S/1000G PCI-Express 4.0 1 TB M.2 SSD (89gb empty space left)
Motherboard:Asus Tuf A620M-Plus
GPU:Galax Geforce Rtx 4070
CPU:Ryzen 5 7500F(CORSAIR H100 RGB Liquid Cooler it is connected to Argb too but it works when case fans dont work)
Ram:Corsair Vengeance 2x8 5200mhz
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Other attached peripherals?
If the fans and lights return to colors that suggests to me that something is "loose". After warming up, there is expansion, the connection tightens up, and all works again.
Key is to discover what that something may be....
Look in Reliability History/Monitor and Event Viewer for any log entries being captured just before or at the time everything starts working again.
There may be some clue be it hardware, software, or configuration.
I updated the post i will look at monitor and event viewer when it happens.
The possibility that the attachments can be loose sounds reasonable cause in some games that make my pc hotter fans open faster.
Latest posts
