The parts I'm planning on using for my first build. Any tips? (Sorry if this is in wrong forum)
dragicornJake
16
I'm 14 and I'm building a new computer for myself. I'm not a hardcore gamer, but I do like high quality. I'm planning on gaming and chatting and web-browsing mostly. Often at the same time. So here is the list of everything I'm getting.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing
(I'm also debating whether or not to upgrade to the Thermaltake Water 2.0 Pro)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150
Memory: (3x-total of 12GB) A-Data XPG Gaming Series 4GB (1 x 4GB) DDR3-1600
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card: MSI Radeon R7 250 1GB
Sound Card: Asus Xonar DG
Wired Network Adapter: Intel EXPI9301CT 10/100/1000 Mbps PCI-Express x1
(I don't know if I need this, but I assumed since I want fast internet
browsing, and would be using ethernet, I might need this.)
Case: NZXT Phantom 410 (White) ATX Mid Tower (Comes with three fans, so I won't be buying
extra case fans.)
Power Supply: Antec 380W ATX12V / EPS12V
Optical Drive: Lite-On ihes112-04 Blu-Ray Reader, DVD/CD Writer
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Monitor: Acer S220HQLAbd 21.5"
Keyboard: Genius Imperator
Mouse: Mouse Cooler Master SGM-2001-BLON1 Wired Optical
Thank's for helping me out!
CPU -> ok
CPU cooler -> ok
MOtherboard -> okay
Memory : Your motherboard does not support tri-channel memory so 12gb would be useless and wouldn't be supported. you need to either pick 8gb or go the way of 16gb.
Soundcard : You can safely exclude that out , if you are not an audiophile and follow onboard audio.
Video Card : Weak. Not a suitable gaming card. Go for r9 270x or Gtx 660 plus.
Power supply : too low. You need a 500W good power supply.
So many things wrong.
Mention your budget, and someone might fix it better for you.
There are some flaws in your build:
You chose an overclockable CPU so it would be a good idea to have an overclockable motherboard (the ASRock Z87 Extreme4 is a really good option for just $110: http://pcpartpicker.com/part/asrock-motherboard-z87extreme4 )
You won't need 12GB of RAM, get 8GB and you'll save some money: http://pcpartpicker.com/part/gskill-memory-f314900cl9d8gbxl
You're cheaping out a lot in the video card, you'll need something much better if you want high quality. Something like this: http://pcpartpicker.com/part/gigabyte-video-card-gvr927xoc2gd
You don't need a sound card.
You're also cheaping out in the PSU. For $20 more, you get something with much higher quality and a lot power, meaning a lot more headroom for future upgrades: http://pcpartpicker.com/part/xfx-power-supply-p1650snlb9
I don't think you need a Blu-Ray reader but if you do that's ok
Also you can find a better monitor for the same price: http://pcpartpicker.com/part/asus-monitor-vs238hp
And maybe you can find some better keyboards and ouses the same price range.
Here is my edited list, but I would like some suggestions for my Optical Drive (under $60). I agree, I don't need a Blu-Ray reader. http://pcpartpicker.com/user/dragicornJake/saved/35B0
Do you also need the network adapter?
I don't know exactly what it is, but I'm assuming I don't need it.
Nah, I don't think you need it.
Overall you have a pretty good build. Personally, I'd change the case to something more discrete and cheaper, like this: http://pcpartpicker.com/part/fractal-design-case-fdcadefr4blw or this: http://pcpartpicker.com/part/corsair-case-400r
And if you're still in your budget I'd change the R9 270X to a GTX 760, that costs $45 more, but the choice is yours: http://pcpartpicker.com/part/msi-video-card-n760tf2gd5oc
Thank you so much. I'm very glad I consulted this forum before I would've bought the parts only to find them not to reach my expectations. So now for a year or so of a lot of referee-ing to get $1200!
