the problem of controller ACPI
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I use a notebook computer Micron Trek 2 AGP U376, I installer windows XP,
all is ok but in the managerment of peripherique (Gestionnaire de
périphérique) the ACPI is conflict with PCI bus , I want use the deffirent
parameter of configuration and I can't because the option parameter base on
(******) is unchangable and the option use the configuration automated is the
same. so my question is how I can changer it!
ps my computer is PII 400/ 256M/ 60G/ AGP 8M
thanx and I am all ears;
G
Guest
Guest
Upgrade the BIOS if possible. If it won't help, reinstall Windows from
scratch with Standard HAL - hit F7 during initial stage of setup.
When you fix HAL issue, buy modern laptop.
G
Guest
Guest
Now I use Linux Mandrank 9 and there is no problem, and I try to upgrade the
BIOS but I can't find the new version for my computer, I will try to
reinstall Windows following what you say, and hope it will be oki. thanx!
G
Guest
Guest
Do not forget to also installed the correct chipset drivers for the laptop
in XP. These may help by placing the correct ACPI drivers into Windows.
"frederic" <frederic@discussions.microsoft.com> wrote in message
news:03E1FA1B-C354-4093-BE79-C54D60DD389F@microsoft.com...
> the
Similar threads
