There is a problem with the computer im having!
nesymerp1
26
When I play games or do something in the computer the computer sometimes randomly crashes saying. ''EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEERRRRR'' Then shuts down.
Ive been very angry at my computer for just crashing for no reason.
It even crashed when I tried to login to my computer.
When I play a game sometimes the whole screen freezes just like the other dumb crashes saying ''EEERRR. '' Then shuts down.
Could someone tell me what the problem is, and any solution to it?
It doesnt show any BSOD.
It only makes a sound like''ERRRR'' and then blacks out.
if this is a pre built dell or hp or other brand the first issue with the system is low wattage and cheap power supply. those low end all in one pc with 200w power supply's not meant for gaming. the next week point is the entry level r3 gpu. the r3 made for web and word. the last point is weak cpu and lack of ram. there are free memory advisors online see if 4g is the max for your pc or if you can go higher. if your getting into all of the newer games out there your better off getting an updated pc.
Mate, its a toshiba.
First of all it crashes when it doesnt do any TASK at all.
and its probably a hardware problem that im having on that laptop.
Fixed the problem! It was a outdated video driver that cuased the crashes.
Luckily I downloaded AMD software which uptated the video driver! Now, I can use the computer in peace.
ROBLOX was going smooth for me.
Which means that this computer can be for light gaming because its going smooth, Its running at 2,00+ GHZ, when maximum 1,80 GHZ on task manager.
Well I guess I solved my OWN problem.
However it does play light gaming! Like ROBLOX.
Now, it has started to crash again LOL.
And there is no way I can know what is happening to it.
do a clean install of windows 10 via usb if you can. only have the one drive you are installing windows to plugged in when you install, delete ALL partitions and install using defaults. then, leave it alone and don't update drivers, let windows do that for you unless you have problems then seek help here.
if that does not fix it, then you probably do have hardware issues
