"There is a problem with the installer package"
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
My PC is P4/2.4 and uses Windows XP (NOT SP2 just yet). I am having trouble
with "missing or corrupted ntoskrnl.exe" and this is a clean install from
the PC vendor's Windows disk.
In order to Restore all my files and data I must install my backup software
(Backup MyPC from Stomp Software. The installation goes OK until the very
end. I then have a dialog box, "Completing the Stomp Backup MyPC Wizard"
with a Finish button. When the Finish button is clicked I receive the
following.
"There is a problem with this installer package. A program required for this
install to complete could not be run. Contact your support personnel or
package vendor."
My Question: "Is this required program a Windows program or one from Stomp?"
Peter.
G
Guest
Guest
Hi, Peter;
According to
http://msdn.microsoft.com/library/en-us/msi/setup/windows_installer_error_messages.asp
that error most probably indicates an issue with the MS Installer 2.0 files.
Here is an article that has several methods for troubleshooting that
problem:
http://support.microsoft.com/default.aspx?scid=kb;en-us;555175
You probably should download/install this update first, even though it says
it is for SP2.
http://support.microsoft.com/default.aspx?scid=kb;en-us;885894
HTH :)
....Sky
> trouble with "missing or corrupted ntoskrnl.exe" and this is a clean
> install from the PC vendor's Windows disk.
> software (Backup MyPC from Stomp Software. The installation goes OK until
> the very end. I then have a dialog box, "Completing the Stomp Backup
> MyPC Wizard" with a Finish button. When the Finish button is clicked I
> receive the following.
> this install to complete could not be run. Contact your support personnel
> or package vendor."
> Stomp?"
G
Guest
Guest
Hi Sky King.
I haven't been to these sites yet but they do look interesting. I'll follow
up ASAP.
Many thanks.
Peter.
"Sky King" <skyking@mvps.org> wrote in message
news:OmVRs2ywEHA.1296@TK2MSFTNGP10.phx.gbl...
> Hi, Peter;
> According to
> files.
> problem:
> says it is for SP2.
> HTH :)
> ...Sky
>> or package vendor."
>> Stomp?"
