Horrible start to my PC upgrade..
Managed to gut the beast. Removed all cables from all hardware that are linked to the faulty PSU. Taken out the Motherboard, GPU, RAM and the network card.
Removed the old HSF and removed the old compound from the CPU and then the CPU followed by unboxing the R1.
I then add the new base plate and bracket for the R1 and proceed to re place the CPU.
CPU pins bent in the process of removal and had to carefully bend back into correct angles.
Could not manage to place the CPU back into to socket and couldn't figure out the issue for about 1 hour max. After that time i put a small amount of pressure on the CPU and it pushed into place. I felt stupid..
I start adding the compound.
Stressed and tired, used up a bunch of the new compound horribly and it left me with a tiny amount to (hopefully) equalise the distribution of heat.
Installed the R1 with great difficulty. Screws would not line up correctly after a multitude of attempts. Roughly 2 hours pass was completely exhausted and refused to give up but I finally did.
My question is I fell like I should by some new compound and wipes and start again. There is not a great amount of compound on the CPU and HSF and im worried if I actually dont have a sufficient amount of Compound. It was like a droplet then what ever I could scrap up from the card I used.
Arrgh.. I feel so stupid... There is a lesson I have learnt. Never do things when you are utterly exhausted.
