S Schxeler Honorable Dec 23, 2013 120 0 10,680 Aug 1, 2014 #1 Does thermal Compound ever become not useable? like does it go bad?
Solution clutchc Aug 1, 2014 As long as you keep the cap on and keep it in at room temp, it will last almost forever.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Aug 1, 2014 #2 Schxeler : Does thermal Compound ever become not useable? like does it go bad? Not if you keep the top on. If you are talking about when it is in service, yes. It dries out over time with age and heat. Upvote 0 Downvote
S Schxeler Honorable Dec 23, 2013 120 0 10,680 Aug 1, 2014 #3 clutchc : Schxeler : Does thermal Compound ever become not useable? like does it go bad? Not if you keep the top on. If you are talking about when it is in service, yes. It dries out over time with age and heat. I just bought a CPU cooler and bought another thing of Thermal Compound, I was just wondering if it goes bad in the syringe. Upvote 0 Downvote
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Aug 1, 2014 Solution #4 As long as you keep the cap on and keep it in at room temp, it will last almost forever. Upvote 0 Downvote Solution
