News Thermal Grizzly's Contact Frame Reduces Alder Lake Temps by 10 Degrees Celsius
But Thermal Grizzly's 12th Gen CPU Contact Frame is not cheap. It costs €39.90 in Germany ($36 without VAT), so everyone will have to decide whether a 10 degrees Celsius difference in temperatures is worth this price.
And the EU should start price gouging investigations...tomorrow?
"Price gouging?" For a totally optional thing you've been doing fine without? Are you serious with this whining? Do you really expect germany to compete with china prices anyway? Yes we must call the lawmakers I'm sure they will get right on this emergency.
So, is Intel going to insist that using this ALSO voids your warranty?
It changes the amount of pressure between the pins and the CPU and intel can't guarantee that everything will keep running fine, so they can't warrantee it.
On the other hand, if you send in a CPU by itself how are they going to tell, other than by the CPU testing out fine.
Reactions: KyaraM
Of course, because you're doing something to the CPU outside of what the manufacturer specified. Heck, AMD won't honor your warranty if you used PBO (but how they'll prove that is up in the air). And at some point, both companies wouldn't honor your warranty if you used an aftermarket cooler (which again, good look to them proving that).
Reactions: Why_Me
Usually the support people just straight up ask people for their bios settings or a list of hardware, most people will answer honestly, mostly because they have no idea what's going on anyway.
People that use this thing will be more knowledgeable so they will know not to mention it.
