Thermal Pads And Temperature Question
ShadiGhabboun
60
Hi all
I have a clevo sager laptop with an AMD HD 6990M GPU... when I play heavy games like metal gear revengeance the GPU temps stay in the rang of 80-83 while playing and it drops to 66 in cut scenes so is this temps high ?! another thing is that I did change me thermal paste and I noticed that the thermal pads are sticky so do you think I should change them or remove them or they don't affect my temps ?! I really need a professional help coz I really cant afford a burned GPU thanks on advance
thanks for your reply
but what about the thermal pads do they affect temps ?! performance ? and do they damage my gpu if they are sticky or if they were removed ?!
do you recommend a specific type or any thermal pad would do it ?!
