Thermal Paste between pins and cpu bit computer still runs fine?
EZTTofficial
13
Exactly as the titles say. In fact I'm using the computer now. Since it is running fine should i be worried? I used the thermal paste given with the Cooler Master Blizzard T2 please help! my computer BSOD'd on startup today and I'm not sure of what the problem is. Should i be worried? :peur:
If the thermal paste is non-conductive or non-capacitive you're fine.
If your paste were either, you'd have fried your CPU or gotten POST failures and BIOS beeps by now.
BSOD is usually a software issue, or maybe RAM.
HOWEVER...To be 100% sure / safe, you DO want to clean it off. A very soft toothbrush + some GooGone will usually get rid of the sticky silocone based pastes. Finish cleaning the surface with some 91% alcohol. Be sure not to bend any pins.
well... i put too much and it went underneath. dumb me squeezed the thing too hard and the whole packet of it went on the CPU all while i was in a stupor of some sort @_@
but im using the PC now so it should be fine right?
