[SOLVED] Thermal Paste help
zbsullivan02
Commendable
Aug 17, 2017
18
Please go easy on me, I have never had to deal with thermal paste and only know a little about it. My cpu has been very hot recently and I need help deciding if this is thermal paste and if it is safe for my cpu. I need thermal paste today and this is the only place that sells it and this is the only item that pops up.
https://www.lowes.com/pd/Gardner-Bender-1-oz-Ox-Gard-Anti-Oxidant-Compound/4514334?cm_mmc=SCE_PLA-_-RoughPlumbingElectrical-_-ElectricalAccessories-_-4514334:Gardner_Bender&CAWELAID=&kpid=4514334&CAGPSPN=pla&store_code=1635&k_clickID=go_625853472_34614745150_111134523790_pla-74096940012_c_9010664&gclid=Cj0KCQiApILhBRD1ARIsAOXWTztoHGF87ilDtUE6D_kF12MWAl5xL-mkMnohZZXA9EKgTSYVm9zyywgaAhqWEALw_wcB
It might work, but it is definitely not designed for that. It is electrically conductive, so you would have to be careful. I wouldn't recommend it. If you have Lowes nearby, I would think you would have a BestBuy. They show several thermal compounds on their website that are also available in-store (for me). I would recommend that first.
