Hi.
Don't ask me how it's possible, and yes, in the future I won't be doing this myself.
The Thermal Paste that is used is the Arctic MX-4 2019 Edition, It's metal-free and not electrically conductive.
As you can see on attached images, there is thermal paste on about 14 CPU pins in the edge of the CPU, where 4 of those are covered all the way to the top, rest on the bottom.
On the motherboard socket, it's on the top left corner and the bottom right corner, and two other holes where I already had it removed gently with a toothpick.
The reason why I stopped myself from going further with removing it, is because I was also stupid enough to have a similar situation happen to me with the exact same thermal paste, the Arctic MX-4 2019 Edition, 3 years ago. That time it was easily 20 times worse than this time, and I ended up not bothering to remove it. That computer has been working without any bluescreens or booting problems, overheating or anything else, for the past 3 years, never had any issues with it due to the thermal paste, and that one is basically soaked in it compared to this one, on both the motherboard cpu socket, and the cpu pins itself.
Next time I will obviously get help with it to not have this situation happen again, but for now:
Would you as a tech expert reading this, still advice me to get Isopropyl alcohol, and a soft tootbrush and have it removed, or just leave it as it is?
I have already booted it up again without any issues, and been running Cinebench with 100% cpu load reaching maximum temperature of 56°C, after having it running for some hours without interruption or issues, because I simply want to avoid risking any damages by trying to remove it.
Thanks.
Thanks.
