R RubenSanchez Reputable Dec 30, 2015 7 0 4,510 Dec 30, 2015 #1 I got thermal paste on my motherboard. Here is a picture! Is it going to affect and can I clean it?? https://drive.google.com/open?id=0B10j1IC9MomjNXJLXzY0WjBuOEE
Solution terry4536 Dec 30, 2015 Yes you can clean it. With the system unplugged and with the capacitors discharged, you can use a Q-tip and rubbing alcohol to clean it up. I doubt that it will have any ill effects though.
terry4536 Glorious Mar 28, 2010 9,741 6 46,265 Dec 30, 2015 Solution #2 Yes you can clean it. With the system unplugged and with the capacitors discharged, you can use a Q-tip and rubbing alcohol to clean it up. I doubt that it will have any ill effects though. Upvote 0 Downvote Solution
R RubenSanchez Reputable Dec 30, 2015 7 0 4,510 Dec 30, 2015 #3 okay thank you! ill take your word for it and leave it as it is! Upvote 0 Downvote
