Thermal paste with heatsink and fan?
MikeFL
17
Hi all,
This might be a silly question, but is thermal paste required even when using a heatsink and fan such as the Cooler Master 212? I'm looking to build a new system soon and would like to be safe rather than sorry.
If so, what would be a recommended thermal paste to use? Also is the Cooler Master 212 a good choice of HSFs?
Thanks in advance for your replies and suggestions.
Even though the CM 212 should come with thermal paste, should I still buy one of the others you recommended? Is there that much of a difference between thermal pastes?
Just for general use I don't think you will notice a difference. It helps a lot to have a good case with good air flow, so don't forget that.
