Hey everyone, so I installed the heatsink onto my Q6600 but I'm really not sure how to install the fan. I looked at the instructions but I'm lost on how to get the clips onto the heatsink, and then how to put the fan onto the clips. Any ideas or tips?
Also, my idle temps are in the mid 30's with prime95 pushing them up to the mid 50's. Do you think this is acceptable for a standard clocked Q6600? Thanks for the help!
