Very few Thermaltake PSU models are good quality, they generally use low end OEM builds for their PSUs. Without hearing the noise myself I'd say toss it. Most likely at a minimum its the bearings in the fan failing.
Could I be able to rma it? Or would they not accept it.
How new is it, its still under warranty?
If its under warranty I don't see why not, they should repair or replace it.
If it was a bad bearing wouldn't it always be grinding instead of an on and off problem.
