Question Thermaltake Core V71 fans - - - installation confusion, manual not helping ?
takearushfan82
179
5
10,585
Hi all. I have an ASRock Z790 Pro RS Wifi motherboard that I'm trying to hook the fans of my Thermaltake up to. The case manual sucks and doesn't really explain much. I see two front fans, one top and one rear. Is anyone familiar with this case? I'm looking for a more detailed guide on what cables to hook up to where, rather than this generic "don't explain anything" picture the manual provides. Thanks for your patience.
It has two in front, one top and one back. I guess what I mean is, the back must connect to cha_fan1, but I wanna make sure the fronts and top are being plugged in properly. Are cha_fan4 and cha_fan5 for the front two, cha_2 and 3 are at the bottom of the mobo so it seems odd to connect it to the top fan. I'm so confused. I'm sorry for my ignorance.
in in the case manual you could hook only the 200 mm fan to this controller check page 14 and 15
I'm sorry. I looked and it's still confusing. I already hooked up the back fan to the typical chassis one port on the motherboard. Do the front two and top fans have separate cables for each one that connect to three different ports on the motherboard?
