Thermaltake Floe Riing 360 RGB RGB not working
nyle_cohen
5
Hi
I just finished building a PC but my Thermaltake Floe Riing 360 RGB AIO cooler is not showing any RGB. When I built it had problems but the RGB was working but the middle fan was not spinning, Now I have left it overnight and all three fans are spinning but no RGB. When I open the Thermaltake software it just says no controller detected when all the fans are plugged in to that controller.
If anyone could help me I would really apreciate it.
Nyle
Hi
Nyle
Hi,
How are you? Since you own the Thermaltake Flow Riing 360 RGB Plus, I thought I'll check with you if you can help.
I managed to fit the Thermaltake Floe ring plus on Thermaltake View 37 case but when I went to connect the AIO Water cooler to the controller, I realised the red cable on the USB connector had popped out. I am now not sure what port was it meant to go. If it is not too much of a pain, may I request you to kindly let me know the location for the red cable.
Image link:
View: https://imgur.com/YtbXyrV
Regards,
Anil
