Question Thermaltake J24 TG ARGB case RGB header question
Mar 14, 2019
So basically, I have absolutely no idea what either of the RGB headers (the black one on the top and the white one on the bottom) do. I tried connecting to the included led connector with the case, but it got really hot and didnt work at all after i connected it to the SPDIF_OUT header on my motherboard (it was the only set of pins that fit the unique 2 pins on one side, one pin gap, 1 pin on the other side thing). I am trying to get the RGB fans to work with my aura sync motherboard, but no luck so far. Any suggestions?
my specs:
Ryzen 5 2600 processor
asus prime b450 plus motherboard
msi gtx 1660 ti gpu
