Thermaltake Offers Up A Tempered Glass View 21
  • Thread starter Thread starter Guest
  • Start date Start date
Seems weird to me slapping glass and a shiny front panel on a cheap case like that. If all I have is $70 bucks for a case on a budget build I probably don't want to see into it. I'm sure some will buy it due to the price though just seems to fit into a really small niche of see though case on the cheap.
I wish they would have had the vertically mounted GPUs like they have in other mid-towers. For this year, I feel dedicated vertical GPU mounts and new materials will be key to case design.
Why cannot they provide only 1 TG side panel instead of 2? They could divert that cost toward thicker metal inside the case. All these new Thermaltake releases(C23, View 28/27, G21... etc) have weak inside constructions, screw in the fan & you notice visible deformation on the mounts...
Way too much emphasis on aesthetics over core functionalities these days. Better check the cases in person at your local stores than ordering online.
