Question Thermaltake RGB CPU Block Help
tracker1
8
I purchased the following parts, wanting to get it all working together.
I did a fair amount of due diligence as I wanted to control everything from the MB/Bios as I'll be running Linux, and wanted to minimize potential RGB support (or lack of) in the near term.
I started putting it all together, just one problem... the CPU block has an RGB Riing style header, and I'm out of ports on the 9-device controller... I don't want to use the USB controller it came with, as I'm unsure about Linux support... again, wanted to use the MB.
There are 4 pins on the CPU block rgb connector (red, white, green, black) ... would these correspond to the other MB header (there are two 4-pin and two 3-pin rgb headers)? I don't want to plug it in and find out I'm wrong. Anyone have any insight into the pin layout for the Thermaltake RGB pins?
