Thermaltake Riing Fans RGB
JoePino
I lost the 4 pin power cable, i cant find any site selling a replacement, any ideas? Another question, the fourth 5 pin connector beside the 4 pin power connector can be used for another fan or no?
Reactions: Shinywraith
I guess you mean something like this?
https://www.newegg.com/Product/Product.aspx?Item=9SIACJ453E3330&cm_re=molex_to_3pin-_-9SIACJ453E3330-_-Product
from here,
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=molex+to+3pin&N=-1&isNodeId=1
narrowed it down,but you can always look for yourself at all their cables.
There are no 5 pin fan headers so i don't think so ... or you must be talking about at the psu cable (molex strand) and in that case that is called a "berg"...
from here,
There are no 5 pin fan headers so i don't think so ... or you must be talking about at the psu cable (molex strand) and in that case that is called a "berg" connector,used to power the ancient floppy drives and most certainly not used to power fans!
https://www.newegg.com/Product/Prod...m_re=molex_to_3pin-_-9SIACJ453E3330-_-Product
from here,
https://www.newegg.com/Product/Prod...TCH&Description=molex+to+3pin&N=-1&isNodeId=1
for the first question...
JoePino means this cable here: https://mgofficial.azureedge.net/pu...rmanual/_0a212a0687e448e3897308dae7545bae.pdf
The cable is the item C, but don't get confused, if you search on the internet "TT RIING CONTROLLER CABLE" they sell the 5 PIN controller cable to connect to other controllers and sync them.
The cable we are searching, instead, is the 4 pin PWM (the should go on the motherboard).
I can't find that cable on the internet and i'm missing that cable too....
the only thing i found is the one fan kit , 21€... that contains that cable of course... https://www.amazon.it/Thermaltake-Ventola-Raffreddamento-Colori-Sequenziali/dp/B014QW98UK/ref=sr_1_1?__mk_it_IT=ÅMÅŽÕÑ&keywords=ring+thermaltake+fan&qid=1560678759&s=gateway&sr=8-1
but i would like to find the cable alone...
(EDIT) also the first link you did write is not avaible anymore 🙁
If it's a problem answering here, you can answer to my non-answered thread with an updated link , maybe, so people that have the same problem can find a solution and don't have to write the same question over and over.
Here Is the link to the question:
Thanks in advance.
