thermaltake silent tower in a tower case?
  • Thread starter Thread starter DS
  • Start date Start date
DS
77
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.periphs.mainboard.asus,alt.comp.periphs.mainboards.asus (More info?)
Hi
I'm thinking of the thermaltake silent tower cpu heatsink/fan, but it seems
a large weight to bolt onto the mobo in a tower case. Has anyone experience
of this heatsink in a tower pc?
Thanks
D
In article <chkvio$4e7$1@news6.svr.pol.co.uk>, "DS" <DS@btinternet.com> wrote:
> Hi
> Thanks
> D
The installation manual is here:
http://www.thermaltake.com/support/installguide/coolers/cl-p0025SilentTower.pdf
For additional pictures, I used this review. There are many reviews
out there, but none I've looked at so far, evaluate Theta-R (thermal
resistance) for easy comparison to other products:
http://www.bit-tech.net/review/321/11
What is good about your A7N8X, is it has four screw holes, so there
is better support than on an Athlon64, with its two screw holes.
There is a backing plate, and basically two H shaped pieces of metal
are bolted to the motherboard. The disturbing part of the design,
is the copper base of the tower, is only held in place by the cross
bar of the upper metal "H". I presume the idea, is the crossbar
functions like a clip - it is a spring and a fastener at the same
time. I guess, when the upper metal H is clamped down to the board
with the four top nuts, the crossbar bends and that bend represents
the spring force and the static load placed on the processor die.
Base clamped in place by bar
--- | | --- ___
|X | | | | X| | | <--- Step in base
| | v v | | | | (side view)
| Top view | | |
|X | | X| ----
| ^^Fan^^ | <-- There is one fan, blowing upward
------------------- toward the PSU.
(Step in base, is on non fan side, and the step goes over top of
the axis of rotation of the ZIF socket lever arm.)
Now, when the heatsink is mounted in your case, it will look
like this, if X-rayed from the end of the tower case looking
towards the front:
PSU casing |
| __________ <---8mm from end of heatsink
| | | | to upper edge of motherboard,
| | | | | exhaust baffles against PSU
| ||| | | Center of mass tries to
| ||+--| | ---- rotate assembly
| ||| | | | downward.
| | | ^^Fan^^ | v
| |<--mobo
Tray
When the center of mass pulls down, the only thing to resist it, is
the clip across the base. The base of the processor and the rubber
cushions on the CPU will presumably be getting some of this force.
Other products have their center of mass closer to the motherboard,
so this is less of an issue. Since the "upper storey" of the
Silent Tower is alum. fins, I expect most of the mass is where
it should be, in the base. So, by using my imagination here, I'm
thinking the CPU is more at risk with this design than the PCB itself.
The back plate stiffens the PCB, to help prevent local bending. But
this is only as effective, as the mounting for the PCB itself. When
the ATX case was designed, no one could have known people would need
a 1.4 pound weight supported under the CPU, and the position of the
mounting points near the top of the board, is less than ideal for
supporting the PCB for a high center of mass heatsink.
Now, if this assembly receives a shock, you can use the same kind of
analysis, to understand what the dynamic force onto the processor
will be. The worst direction for a shock, is a rocking motion of
the tower, and I wouldn't expect too many G's that way without
knocking the computer case right over. As the heat pipes would
bend under a shock, the analysis of what happens would be more
complicated than for a heatsink fastened directly to the PCB.
Apparently, on some motherboards, the direction of airflow from
this product, is towards the back of the computer and the case exhaust
fans. If I've done my imagining correctly, the A7N8X install will blow
towards the PSU, and the clearance from the exhaust of the Silent Tower
is: 8mm + clearance_from_mobo_to_PSU_casing. My guess is based on a
80mm depth dimension through the fins, halved gives 40mm, and distance
from center of A7N8X socket to top edge of motherboard is roughly
48mm. Having the air baffle against the PSU isn't too good.
I don't know of any data or articles on bending of PCBs, so I cannot
give a number for what a bad load on a PCB would be. None of the
reviews of this product expressed any reservations, so I guess they
didn't see any deflection in the PCB.
In the review above, of the five heatsinks, I'd select the
Thermalright based on how it mounts to the board (spring loaded
screws topside). You can remove it without having to remove the
motherboard. Have a look on the Thermalright site, for compatibility
info and AMD heatsink models.
This review shows several Thermalright models at the top of the
list:
http://www.overclockers.com/articles373/socketA.asp
Silentpcreview also has some nice review articles:
http://www.silentpcreview.com/article132-page4.html
I use a Zalman 7000a AlCu on my P4C800-E and it isn't a bad product.
I can still hear the fan, and run it at full speed. But the mounting
method varies with socket type, and there is also the clearance issue
to the PSU on a A7N8X board to consider (about 8mm min from top edge
of motherboard to PSU casing), so one of the Thermalrights might be
less of a hassle. For the Thermalright, you'll need a fan
with a tachometer output, to be able to monitor the fan speed, and
finding a good one will be the hardest part of your purchase. Panaflo
fans are nice, but you have to be careful when buying them, because not
all models have tacho outputs. The ones ending in "BX" part numbers
might be good ones based on this catalog page. CFMs vary according
to whether the fan is a low, medium, or a high. The FBA09A12L1BX looks
like a nice 92x25mm fan, with tacho output. It should be quiet at
full speed. A FBA09A12H1BX is another option, but would need a
FanMate voltage reducer to make it run quiet (H is hi speed).
http://dkc3.digikey.com/PDF/T043/1297.pdf
HTH,
Paul
