[SOLVED] Thermaltake smart rgb 600w
PC - https://pcpartpicker.com/list/ttQFMc
I was planning on getting a thermaltake smart rgb 600W but after reading some reviews is it really that bad?
If its that bad can someone find me a solid one under $80 on this site - gigatron.rs/napajanja
$80 is about 9000RSD
Gigatron's selection sucks. That's the only place?
The HEXA 85+ is the only PSU I would ever consider if I had to buy from that place and only had a 9000RSD budget: https://www.gigatron.rs/napajanja/fsp_napajanje_650w_hexa_85_serija__ha650-139058
Apr 23, 2020
19
This place seems MUCH better...
https://www.sigma-computer.com/item?id=693
https://www.sigma-computer.com/item?id=267
https://www.sigma-computer.com/item?id=264
Looks like they only have higher wattages, though. I guess Egyptian retailers equate high wattage with high quality and never order high quality low wattage PSUs?
I am from Serbia.
I found these idk if they are strong enough for the build i have:
Apr 23, 2020
19
I will say that if the TX-M is only 7 Euro more than the CX, totally get the TX-M.
That pricing seems out of whack because the TX-M has Gold efficiency and is semi-modular. The CX is Bronze and non-modualr.
Ok getting the txm but isn't the cxm also semi-modular?
Oh.. You're right! That's a CX-M!
So then the TX-M is MUCH better.
The CX is better than the CX-M, but the TX-M is MUCH, MUCH, MUCH better than the CX-M.
That makes it a no brainer. No reason why the cost delta between CX-M and TX-M should be so small. Man.. Pricing is all over the place. It's like they have a bot doing it.
