Thermaltake TR2 600W problems! Should i try to get it RMA'd?
jasonhickman17
197
So, after a bit of looking it seems as though the tr2 is not liked by the vast majority of the people on this forum, but i am having a bit of a concerning issue.
Sometimes, when i boot down the PC, the computer wont turn back on, the power supply's switch has to be turned off, power cord unplugged, plugged back in, and switch turned back on then the computer may boot and if it doesnt the process has to be repeated sometimes up to three times. I have tried just wiggling the cable about and that alone doesnt work.
I am worried this may be a fire hazard, if you know what this is any information is welcomed and greatly appreciated.
Thanks in advance!
Jason H
Oh okay thanks, my computer is as follows:
Gigabyte GA970HD3P
Seagate Barracuda 2TB
AMD FX6300
Kingston Hyper X 8GB
XFX R9 280X 3GB DD
And i think that is all that is in there, thanks for the help!
Jason H
Thank you everyone for the replies i am going to get in touch with thermaltake first to see what they are going to do about it, then i will probably get the evga supernova, i am using it in my most recent build at the moment!
Thank you all for the help that was fast!
JasonH
