Hey. So I'm working on my first build and after a couple issues I've got everything working pretty much and I can get to BIOS and whatever. The only problem is the fan on my cpu is grinding against the heatsink and it's ridiculously loud. I didn't bend it or anything, but it seems like an expected problem with the design, having the fan right between two big sets of flimsy fins. Do you think it's rubbing because it's not hooked on the motherboard correctly? It doesn't seem like it would be but i don't know anything else i could have done wrong. My other thought is to take it out and sand the fins down a little in one spot but I'm not sure. Anyone else have a similar problem or any input? Thanks,
