Thermaltake Versa C21 power connectors
paradise14z
7
I'm currently working on and building a new PC using the Thermaltake Versa C21 and a Asus 970 Aura.
The case has these 2 connectors on these very small wires that are labeled POWER. Both of them look exactly like PCIE connectors you would plug into a graphic card. They both have male and female ends on the front and back side respectily. The manual for the case and the motherboard don't mention these 2 wires and connectors anywhere.
So....where do they go? I tried plugging them into the female ends of the other pcie connectors on the power supply and I tried them again with the male ends. I tried them again all plugged in.
The motherboard does light up so I know the power supply is good. I'd love some help on this. Thanks
First off, did the extension cables come with your PSU or the chassis?
Second, what connections are you talking about? There are only two main power connectors,
The 8 pin EPS cable on the top left and the 24 pin main connector on the mid right of the board.
http://www.tomshardware.com/answers/id-3379314/case-molex-connectors-fans-leds.html
This is the same problem I'm having. It took me way too long to find this thread. Those POWER connectors are the 2 I'm referring to. I tried plugging them into the power supplys other connectors like that. My supply only has 1 hole in it and it's taken up entirely by this type of connector and then the 8 and 24 pin connectors.
Then on the end of the long strip of these connectors from the supply is a connector that's 4 pin and it only says ZTP on it. I have no clue where that goes either. The manuals for either the case or the motherboard mention this
