Thermaltake Versa H24 Front Panel Trouble
ASheepOnAShip
25
Hey guys, so I just received my new Thermaltake Versa H24, and was taking a look around when I realised that I didn't see any way to get the front panel off. The manual simply says "Pull out the front panel", but I still don't understand how it works. If anyone knows how to take it out, please tell me!
There should be a finger grip opening under the front panel. Hold back against the case and give it a tug. You have to pop the locking posts out of their sockets.
I also discovered this with my Versa H34. The key is to slowly pry it off the first time and then coat the pins with silicone grease. From that point on, it is very easy to remove as needed.
