Thermaltake View 71 RGB or Corsair 570X RGB
currently i have the CM690III case
with 2 GPU's in it it gets hot up here is my case image just in case its just there is no space
wanted to buy a new case which has good airflow so that GPU stays cool and case should be pretty solid
i have these 2 in my mind
but have some doubt is the glass case is good for longer life time? what about scratches and all?
which case has good airflow?
and yes in image sound card is missing i also have Creative ZXR
Tempered glass is a great sound reducer and insulator but it is heavy. I would not worry about scratches.
I have a Phanteks Enthoo Evolv Mid ATX. And I'm cooling a 7700k and a MSI 1080ti. It took me awhile to get the airflow correct. Not counting the PSU I six fans - five blowing out and one (bottom front with filter screen) blowing in. Two of the fans are for a cooling radiator. This configurattion brought all my temps down. With a negative pressure scheme I put 30ppi foam over the case holes to catch dust that would be drawn into the case. The insides stay very clean.
Both those case look great. If you plan to use a liquid CPU cooler in the future keep that in mind for the case size.
