Thermaltake water 2.0 and overheating CPU
taylorc
9
Hi there,
I noticed my PC was running very sluggish whenever I would try to run something CPU intensive. I restarted my computer to check the temps aaaand the CPU was sitting around 90c. I've had a Thermaltake water 2.0 on my comp for about 2 years now. I felt the two tubes running from the pump to the CPU and only one of them was hot. I'm guessing that the pump is broken? I'm hoping this is not the case.. any ideas on things I can try?
Thanks! :)
just had this same problem with my lil bros water 2.0 take the 2 fans and radiator apart and make sure the radiator isnt clogged his had alot of dust in it so one tube was staying hot now we are having no issues
