I bought and installed Thermaltake's Water 2.0 Extreme clc. I mounted it to my cpu and then installed the radiator and two fans to the top of the haf xm case. Then, I plugged the pump into the USB header on the board, plugged my two fans into the "pump"/mounting block, and then the mounting block into the CPU_FAN header. Next, I installed the software that came with the thermaltake product. Now here's my two issues...First, I am getting no values for the RPM of the two fans connected to the radiator. They power on and work, but I think they're at a constant speed even when the cpu warms up. I'm worried they won't increase in speed when needed. Neither the BIOS or the ASUS windows program recognizes them as being connected. However, if I connect a fan to the same header by itself, it recognizes it. What could be the issue here?
Secondly, the software that came with the product doesn't launch. It says there's an error with the USB connection (which I checked multiple times). Any ideas?
