Thermaltake's Chaser MK-I LCS Case with Liquid Cooling
I don't particularly care for Thermaltake designs, but this looks pretty sweet. A halfway decent water cooling solution too, better than a lot of the AIO coolers I see bundled with some cases. Question is, can they price it to sell?
Built with the e-sports gamer in mind, the chassis itself will sport two USB 3.0 ports, two USB 2.0 ports, a top-mounted HDD hit-swap docking station
I need one of thoose hit-swap docking stations, just toss out the old music and in with the next you want =P
Wonder if you can disable the light glow on these cases.
I hate it at night time when your sleeping and the PC is on with light glows
soo annoying
[citation][nom]evilgummybear[/nom]Wonder if you can disable the light glow on these cases.I hate it at night time when your sleeping and the PC is on with light glowssoo annoying[/citation]
real computers don't need lights to work
Thermaltake watercooling has been nothing short of disastrous in the past...Big Water kits leaked or corroded due to aluminum components mixed with brass and copper in the loop. Aluminum should never be used for PC watercooling...at all. TT pumps have also been notoriously weak, pushing minimal flow and very low head pressure through the system.
I really laugh when a company releases a 'case with built in water cooling' and don't educate the end user that you will need more than a 240 radiator to cool a CPU and GPU...or even 2 or 3. You really should use a 240 (minimum) for EACH CPU or GPU in the loop.
To update-
Features
- Bigwater 850GT Liquid-Cooling solution
- Breath Lighting effect
- USB3.0 superspeed
- Top-mounted HDD hot swap Docking Station
- VGA TripleMax 33cm
- CableClear cable management
- Innovative 5.25” & 3.5” tool-free design
- Combat Headset Holder
- Heightened footstand enhances intake airflow
No thanks...I'd pass anyway...but now I will also tell everyone I know to also pass.
Turn off your computer then
Yet another overstyled funny looking design from Thermaltake. The case might have great features under all that gaudiness but I wouldn't want to look at that thing every day.
Too much bling. I get that 15 year old gamers want their cases to look like bad taste christmas trees, but I would love a sober, elegant case for a change.
[citation][nom]gento1[/nom]I love my iPad but this is one of the most utterly pointless ideas I have heard for a while.[/citation]
Yeahp, we can all definitely see the relationship between this case and your iPad.
