hi,
i saw some really bad design things on those new btx mother boards.
1.) the btx motherboards are having their ide, sata and power connection directly in the path of the air flow. if they move the power connector towards the psu and drive connections towards the other end or towards the drive cage it wudnt restrict the air flow.
2.) the air tunnel for cpu isnt that great a idea. it stops the cooling of elements around the cpu. also hot air from the cpu blows over to graphics and north and south bridge.
3.) ram get next to no cooling unless there are more fans.
4.) btx cabinets support unusually high number of fans. Y is that.
