Hi guys, i have bought 2 120mm blue LED Cougar fans for my Thermaltake V4. Thing is, when i was installing the first fan, i've noticed that this chassis is too small for somethings... I tried to use the rubber grommets on the front with the intake fan, but i couldn't. had to use the regular grommets.
On the top slot for the fan, i couldnt put it there becouse the fan itself would hit the ram memory slots...
I did a research for thinner fans and all i found was about Scythe fans. I guess it would solve my problem, but since i'm a bit obssesed with all the fans having a LED, i'm still searching a 120mm x 120mm x 12mm that MAYBE could fit on the top slot.
Is ther such thing as a 120mm x 120mm x 12mm fan with LED?
